Aller au contenu principal
Neato XV-21 Battery Replacement/Removal
Ce dont vous avez besoin
  1. Neato XV-21 Battery Replacement/Removal, Back Panels of Neato XV-21: étape 1, image 1 de 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Battery Replacement/Removal: étape 2, image 1 de 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Battery Replacement/Removal: étape 3, image 1 de 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Battery Replacement/Removal, Battery: étape 4, image 1 de 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
3 autres ont terminé cette réparation.
Fernando Aguilar
Membre depuis le 09/25/17
159 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Can someone tell me the specs of screws for the back panels? unfortunately I lost the 8 screws!!!
mflorest - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 18
30 derniers jours : 55
Total : 1,126
