Introduction
A damaged or missing trigger spring can prevent your rifle from firing. This guide shows you how to access and replace the small trigger spring in the Nerf N-Strike Elite Alpha Trooper CS-12.
Ce dont vous avez besoin
Be sure that the rifle is discharged and unloaded before starting disassembly.
Looking at the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
Pull off the orange cap.
With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together.
Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
Remove the two halves of the slide mechanism.
Remove the single 8mm phillips screw holding the trigger mechanism is place.
Remove the trigger mechanism.
Remove the small spring from the rear of the mechanism and replace it with a new spring.
2 autres ont terminé cette réparation.
