Aller au contenu principal
Nerf N-Strike Elite Retaliator Case Disassembly
Ce dont vous avez besoin
  1. Nerf N-Strike Elite Retaliator Case Disassembly, Case Disassembly: étape 1, image 1 de 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Case Disassembly: étape 2, image 1 de 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Case Disassembly: étape 3, image 1 de 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Case Disassembly: étape 4, image 1 de 2 Nerf N-Strike Elite Retaliator Case Disassembly: étape 4, image 2 de 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Case Disassembly: étape 5, image 1 de 2 Nerf N-Strike Elite Retaliator Case Disassembly: étape 5, image 2 de 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
Ligne d'arrivée
28 autres ont terminé cette réparation.
ericharman
Membre depuis le 03/02/16
1 410 Réputation
5 tutoriels rédigés
14 commentaires
How do I clean the slider track?
devinwhaley - Réponse
you probably should not do that. i think its oily for a reason.
one smol birb -
You shouldn't. That oily substance is lubricant, which is crucial for smooth functionality.
SirMikay -
Mine had a chopped off dart head stuck in the trigger mechanism.
I had to partially disassemble in order to be able to free the slide which was covering 1 screw.
Overall, it was very easy. Only challenge is keeping track of the screws, as they're not all the same.
Pete Isaacs - Réponse
Boo this sucks
Mark Green - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 27
30 derniers jours : 161
Total : 34,786
