Aller au contenu principal
Nerf N-Strike Maverick O-Ring Replacement
Ce dont vous avez besoin
  1. Nerf N-Strike Maverick O-Ring Replacement, Nerf N-Strike Maverick Teardown: étape 1, image 1 de 1
    • The Redeemer. Looks badass with its rotating barrel, but it's going to get a whole lot more badasserer quite soon...
    • Reminds me of a gun from the Fifth Element.
  2. Nerf N-Strike Maverick O-Ring Replacement: étape 2, image 1 de 1
    • First thing's first: let's remove some screws. All screws are conveniently Phillips, and all can be removed with a #0 or #00 size screwdriver.
    • Remove all ten Phillips screws.
  3. Nerf N-Strike Maverick O-Ring Replacement: étape 3, image 1 de 3 Nerf N-Strike Maverick O-Ring Replacement: étape 3, image 2 de 3 Nerf N-Strike Maverick O-Ring Replacement: étape 3, image 3 de 3
    • Another Phillips screw hides beneath the cocking mechanism thing. Remove that one as well.
    • The cocking mechanism's quite simple. A metal lever pulls back on the air plunger and compresses the large spring. Another small spring returns the slider back into its original position once it's done doing the dirty business..
  4. Nerf N-Strike Maverick O-Ring Replacement: étape 4, image 1 de 2 Nerf N-Strike Maverick O-Ring Replacement: étape 4, image 2 de 2
    • And just like that, the gun comes apart.
    • Visible in the top left corner is the large spring and air plunger.
    • I later opened the gun again and put a folded piece of paper in this area. It gave the gun a bit more "punch" when sending darts on their merry way.
  5. Nerf N-Strike Maverick O-Ring Replacement: étape 5, image 1 de 1
    • Gun tip. I foresee it being black in the future.
  6. Nerf N-Strike Maverick O-Ring Replacement: étape 6, image 1 de 2 Nerf N-Strike Maverick O-Ring Replacement: étape 6, image 2 de 2
    • First comes out the air plunger. It lifts right up.
    • The barrel comes out next.
  7. Nerf N-Strike Maverick O-Ring Replacement: étape 7, image 1 de 2 Nerf N-Strike Maverick O-Ring Replacement: étape 7, image 2 de 2
    • The trigger is held in place by a sole Phillips screw. It also has a small spring for that authentic handgun "springy" feeling...
  8. Nerf N-Strike Maverick O-Ring Replacement: étape 8, image 1 de 3 Nerf N-Strike Maverick O-Ring Replacement: étape 8, image 2 de 3 Nerf N-Strike Maverick O-Ring Replacement: étape 8, image 3 de 3
    • The trigger's spring also attaches via a Phillips screw. A couple of twists with the screwdriver and it comes right out.
    • The fancy rotator for the barrel is next. I assume that were the gun to break, this would be the part that fails. It's the most complex part of the gun.
  9. Nerf N-Strike Maverick O-Ring Replacement: étape 9, image 1 de 1
    • Looking down the gun's business end.
    • I didn't bother to take the barrel apart. I didn't feel that adventurous.
  10. Nerf N-Strike Maverick O-Ring Replacement: étape 10, image 1 de 1
    • Here it is -- the whole gun taken apart.
    • It's so easy to assemble, a child could do it. Maybe Nerf's motto is "From our kids to your kids"?
    • I sincerely hope Nerf products are manufactured in countries that have strict child labor laws. I in no way, shape, or form condone child labor.
  11. Nerf N-Strike Maverick O-Ring Replacement: étape 11, image 1 de 2 Nerf N-Strike Maverick O-Ring Replacement: étape 11, image 2 de 2
    • The finished product.
    • I took the gun to work and shot these pictures under a better lighting/camera setup... A much better lighting/camera setup.
  12. Nerf N-Strike Maverick O-Ring Replacement, The Beginning: étape 12, image 1 de 1
    • Follow steps 1 through 4 of the Nerf N-Strike Maverick Teardown guide.
  13. Nerf N-Strike Maverick O-Ring Replacement, Locate the Gasket: étape 13, image 1 de 1
    • Locate the air plunger in the upper left hand corner of the opened nerf gun. Push back on the spring and carefully pull the plunger toward you to remove it.
  14. Nerf N-Strike Maverick O-Ring Replacement, Locating the O-Ring: étape 14, image 1 de 1
    • Once you have the air plunger removed, locate the O-Ring by pulling the two pieces of the air plunger apart.
  15. Nerf N-Strike Maverick O-Ring Replacement, Removing the O-Ring: étape 15, image 1 de 1
    • Use a pair of tweezers to remove the O-Ring from the top of the air plunger.
  16. Nerf N-Strike Maverick O-Ring Replacement: étape 16, image 1 de 1
    • Follow steps 1 through 4 of the "Nerf N-Strike Maverick Teardown" guide in reverse order to reassemble the gun.
tanika gorham
Membre depuis le 11/05/14
19 Réputation
1 tutoriel rédigé
Équipe
University of Maine, Team 1-2, Diaz Fall 2014 Membre de l'équipe University of Maine, Team 1-2, Diaz Fall 2014
UMAINE-DIAZ-F14S1G2
3 membres
3 tutoriels rédigés
Un commentaire
What size o ring did you use?
Jeffrey Wilder - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 6,467
