Aller au contenu principal
Nerf Recon CS-6 Barrel Replacement
Ce dont vous avez besoin
  1. Nerf Recon CS-6 Barrel Replacement, Remove Magazine: étape 1, image 1 de 1
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
  2. Nerf Recon CS-6 Barrel Replacement, Remove Visible Screws: étape 2, image 1 de 1
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Nerf Recon CS-6 Barrel Replacement, Remove Hidden Screws: étape 3, image 1 de 2 Nerf Recon CS-6 Barrel Replacement, Remove Hidden Screws: étape 3, image 2 de 2
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
  4. Nerf Recon CS-6 Barrel Replacement, Remove Plunger Cap: étape 4, image 1 de 1
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Nerf Recon CS-6 Barrel Replacement, Remove Slide Screws: étape 5, image 1 de 1
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Nerf Recon CS-6 Barrel Replacement, Split the Gun in Half: étape 6, image 1 de 2 Nerf Recon CS-6 Barrel Replacement, Split the Gun in Half: étape 6, image 2 de 2
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
  7. Nerf Recon CS-6 Barrel Replacement, Remove Spring: étape 7, image 1 de 2 Nerf Recon CS-6 Barrel Replacement, Remove Spring: étape 7, image 2 de 2
    • Pull the spring out the back of the gun.
  8. Nerf Recon CS-6 Barrel Replacement, Removing Plunger Guide: étape 8, image 1 de 1
    • Lift the plunger guide straight up out of the gun.
  9. Nerf Recon CS-6 Barrel Replacement, Remove Plunger: étape 9, image 1 de 1
    • Pull the plunger out the back of the gun off of the inner piece.
  10. Nerf Recon CS-6 Barrel Replacement, Remove  Other Half of Plunger: étape 10, image 1 de 1
    • Pull the remaining half of the plunger out the back of the gun.
6 autres ont terminé cette réparation.
Pam Ruffner
Membre depuis le 10/20/14
984 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team 8-14, Williams Fall 2014 Membre de l'équipe Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 18
Total : 4,558
