Introduction
You will only need a screwdriver to take apart this Nerf gun and access the loading spring. Also obtain a new spring if needed.
Pièces
Aucune pièce nécessaire.
The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
  • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
  • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
  • Both sides of the slide will come off when the screws are removed.
Ajouter un commentaire
Lift both slide pieces off of the gun.
  • Lift both slide pieces off of the gun.
Remove the twelve #00 1 cm Phillips screws. Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
  • Remove the twelve #00 1 cm Phillips screws.
  • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
  • Rotate the gun so that the front is facing you to remove the final screw.
When removing the cover, the clip attachment and the spring will likely fall out of the gun.
  • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
  • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
  • The magazine will slide down automatically as you remove the cover.
Lift the spring out towards you. Lift the spring out towards you.
  • Lift the spring out towards you.
Cara Pew
Membre depuis le 29/09/2014
854 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 13-6, Forte Fall 2014 Membre de l'équipe Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 27
Total : 721
