Introduction
When replacing the base motherboard, removal from the wall is necessary and power to the thermostat must be turned off. The tools required are the blue opening tools, spudger, and a #0 Phillips screwdriver.
Before disassembling your Nest Thermostat, be sure that your HVAC system is powered off. Grasp the display's metal outer ring with your fingers and pull directly away from the wall, leaving the base behind. Grasp the display's metal outer ring with your fingers and pull directly away from the wall, leaving the base behind.
  • Before disassembling your Nest Thermostat, be sure that your HVAC system is powered off.
  • Grasp the display's metal outer ring with your fingers and pull directly away from the wall, leaving the base behind.
Ajouter un commentaire
Remember to turn off the power to your HVAC system and the thermostat. Disconnect all wires from the grey spring-loaded connectors. This can be done using your fingers. Disconnect all wires from the grey spring-loaded connectors. This can be done using your fingers.
  • Remember to turn off the power to your HVAC system and the thermostat.
  • Disconnect all wires from the grey spring-loaded connectors. This can be done using your fingers.
HOW do you disconnect the wires? I can't get them out!
Beverley Brown - Réponse
Same here. It is like the springs are in a stuck position
Bill Redfield - Réponse
I also can not dis-engage the wires. Feels like the springs are frozen closed.
Hold down the button on the end and the wire should be able to slide right out.
Amber - Réponse
Remove the two 40mm screws from the base of the thermostat using a #0 Phillips screw driver.
  • Remove the two 40mm screws from the base of the thermostat using a #0 Phillips screw driver.
Unsnap the base from the trim plate (if used) using a plastic opening tool. Unsnap the base from the trim plate (if used) using a plastic opening tool. Unsnap the base from the trim plate (if used) using a plastic opening tool.
  • Unsnap the base from the trim plate (if used) using a plastic opening tool.
Turn the base over. Remove the four 6 mm screws from the back of the base using a #0 Phillips screwdriver.
  • Turn the base over.
  • Remove the four 6 mm screws from the back of the base using a #0 Phillips screwdriver.
Pry the base mother board open from the side using the a plastic opening tool. Pry the base mother board open from the side using the a plastic opening tool.
  • Pry the base mother board open from the side using the a plastic opening tool.
The base mother board is only held together by light adhesive. Pry the baseboard from the bottom using the flat end of a spudger. Pry the baseboard from the bottom using the flat end of a spudger.
  • The base mother board is only held together by light adhesive.
  • Pry the baseboard from the bottom using the flat end of a spudger.
4 autre(s) ont terminé cette réparation.
Rachael Deptula
Membre depuis le 03/09/2014
496 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 11-5, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 11-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G5
5 membres
6 tutoriels rédigés
Would like to know where I can get just the base motherboard.
wesbug - Réponse
Where can we purchase replacement parts?
brettspradley - Réponse
i want the baseboard.. where i can buy? pls help...
john gemora - Réponse
Yep, my base unit lasted exactly 8 days, then it shorted out. The furnace repairman said he has seen it a couple of times, the base unit can't handle the current needed by the furnace so it goes poof. Back to Honeywell...
bbolen - Réponse
No replacement parts from Nest, my base unit died and I have perfectly working thermostat but am forced to buy a new one cause I can't get the base unit on its own.
Adrian Ma - Réponse
I have no clue why people like their thermostats to the degree that they do.. I am both an A/c professional and an Engineer. They use what is called an SCR or silicon controlled rectifier for their switching instead of a tiny relay. An SCR is very sensitive to a spark or voltage spike. Yes the thermostat is pretty cool and has some nice features. It is advanced electronics but using SMC's or Surface Mounted Components?? . Maybe that would work well in a shielded component. But NOT in something that is connected to long external wires. The consumer bought warranty is only one year. I have seen too many issues in the field with their overpriced toys. Not having parts for this Chinese made thermostat? Priceless.
Jon Reid - Réponse
Voir les statistiques:
Dernières 24 heures : 97
7 derniers jours : 467
30 derniers jours : 1,795
Total : 34,163
