Introduction
This guide will allow you to separate the motherboard from the lower case.
Pièces
Aucune pièce nécessaire.
Rotate the device so that the bottom is facing up.
  • Rotate the device so that the bottom is facing up.
Ajouter un commentaire
Lift up all four rubber pads on the bottom of the router with the plastic opening tool. Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
  • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router. Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
Lift the bottom casing straight up from the router.
  • Lift the bottom casing straight up from the router.
Remove the clear plastic casing by lifting it straight up from the router.
  • Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router. Separate the motherboard from the top shell by lifting it straight up from the router.
  • Separate the motherboard from the top shell by lifting it straight up from the router.
Ryan Murphy
Membre depuis le 03/10/2011
482 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 21-24, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 13
Total : 1,703
