Aller au contenu principal
Nexus 9 USB Daughterboard Replacement
Ce dont vous avez besoin
  1. Nexus 9 USB Daughterboard Replacement, Rear Case: étape 1, image 1 de 3 Nexus 9 USB Daughterboard Replacement, Rear Case: étape 1, image 2 de 3 Nexus 9 USB Daughterboard Replacement, Rear Case: étape 1, image 3 de 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 USB Daughterboard Replacement, Vibrator Daughterboard: étape 2, image 1 de 1
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
  3. Nexus 9 USB Daughterboard Replacement: étape 3, image 1 de 2 Nexus 9 USB Daughterboard Replacement: étape 3, image 2 de 2
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  4. Nexus 9 USB Daughterboard Replacement: étape 4, image 1 de 3 Nexus 9 USB Daughterboard Replacement: étape 4, image 2 de 3 Nexus 9 USB Daughterboard Replacement: étape 4, image 3 de 3
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
  5. Nexus 9 USB Daughterboard Replacement: étape 5, image 1 de 1
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
  6. Nexus 9 USB Daughterboard Replacement, USB Daughterboard: étape 6, image 1 de 1
    • Remove the single 3mm T5 Torx screw.
    • Use a spudger to disconnect the display ribbon cable ZIF connector.
    • Gently lift the USB daughterboard up from the device.
3 autres ont terminé cette réparation.
Geoff Wacker
Membre depuis le 09/30/13
89 956 Réputation
89 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 3,558
