Pièces
Aucune pièce nécessaire.
Using the plastic opening tool, push the blade into the space between the case and lower cover. Turn the opening tool slightly, the lower cover will detach on that side.
  • Using the plastic opening tool, push the blade into the space between the case and lower cover.
  • Turn the opening tool slightly, the lower cover will detach on that side.
  • Repeat on other side of the seam.
  • The lower cover will slide off.
Ajouter un commentaire
Remove the one T5 Torx screw
  • Remove the one T5 Torx screw
  • Remove the one #00 Philips screw
  • Lift up the end of the antenna housing and slide it outwards.
  • The vibrator is located on the back of the antenna housing.
  • Use the spudger to pry up on the axle of the motor.
Niklas Johnson
Membre depuis le 31/01/2012
1 063 Réputation
18 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,507
