Aller au contenu principal
Nexus Q Ball Bearing Ring Replacement
Ce dont vous avez besoin
  1. Nexus Q Ball Bearing Ring Replacement, Ball Bearing Ring: étape 1, image 1 de 1
    • Squeeze and pull the cap to remove it from the Nexus Q.
  2. Nexus Q Ball Bearing Ring Replacement: étape 2, image 1 de 1
    • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
  3. Nexus Q Ball Bearing Ring Replacement: étape 3, image 1 de 1
    • Undo the ZIF connector by prying it with a spudger.
  4. Nexus Q Ball Bearing Ring Replacement: étape 4, image 1 de 1
    • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
    • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
  5. Nexus Q Ball Bearing Ring Replacement: étape 5, image 1 de 1
    • View the bottom half of the Nexus Q.
    • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
  6. Nexus Q Ball Bearing Ring Replacement: étape 6, image 1 de 1
    • Remove the ball bearing ring.
    • When placing a new ring in its place, make sure to orient it right or the top will not close.
Taewan Kim
Membre depuis le 01/31/13
22 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-10, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 554
