Introduction
Replace your worn out inner dome daughterboard: which contains Atmel ATMEGA328P, NXP Semiconductors 44501 Near-Field Communications Controller, TXC 8.00 MHz Crystal Quartz Oscillator, YF04E, and the status LED.
Squeeze and pull to pop the cap off of the Nexus Q.
  • Squeeze and pull to pop the cap off of the Nexus Q.
Ajouter un commentaire
Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger. Once the antenna is disconnected, simply pull it off the outside of the inner dome.
  • Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
  • Once the antenna is disconnected, simply pull it off the outside of the inner dome.
Why remove the anntenna? what did it do to you?
rudyt83 - Réponse
Undo the ZIF connector by prying with a spudger.
  • Undo the ZIF connector by prying with a spudger.
Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
  • Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
  • Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
Use a spudger to disconnect the daughterboard from the ZIF connector.
  • Use a spudger to disconnect the daughterboard from the ZIF connector.
Alex Thomas
Membre depuis le 31/01/2013
27 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 7-10, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 769
