Introduction
Replace the outer casing of your camera if it is damaged.
Pièces
Aucune pièce nécessaire.
Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
Ajouter un commentaire
Turn camera upside down so that the battery compartment is facing you.
  • Turn camera upside down so that the battery compartment is facing you.
  • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
Rotate the camera to the opposite side where the A/V outlet is located.
  • Rotate the camera to the opposite side where the A/V outlet is located.
  • Unscrew and remove all four screws with a Phillips 00 screwdriver.
Turn the camera so that the Wi-Fi adapter is facing you.
  • Turn the camera so that the Wi-Fi adapter is facing you.
Using a plastic opening tool, pry the front casing of the camera. Continue this motion all around the front casing of the camera. Gently pull apart the front casing from the rest of the camera.
  • Using a plastic opening tool, pry the front casing of the camera.
  • Continue this motion all around the front casing of the camera.
  • Gently pull apart the front casing from the rest of the camera.
Using the plastic opening tool pry the back casing of the camera.
  • Using the plastic opening tool pry the back casing of the camera.
Orange ribbon is fragile
  • Orange ribbon is fragile
  • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
Pull down the on the black latch to carefully separate the orange ribbon from the motherboard. Pull apart the orange ribbon and front casing from the rest of the camera.
  • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
  • Pull apart the orange ribbon and front casing from the rest of the camera.
Jessica Brough
Membre depuis le 22/01/2012
105 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-28, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 3-28, Amido Winter 2012
CPSU-AMIDO-W12S3G28
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 946
