Introduction
This guide is to be used to install the battery in the case that the battery dies or no longer functions properly. A Phillips screwdriver will be needed to complete this installation.
Outils
Aucun outil requis.
Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
  • Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
    • This will cause the SD/Battery cover to pop open.
Ajouter un commentaire
Press orange clip to eject battery (battery not shown).
  • Press orange clip to eject battery (battery not shown).
While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
  • While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
    • This will cause the battery to fall into the hand (battery not shown).
Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
  • Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
  • Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
3 autre(s) ont terminé cette réparation.
Patty Richeson
Membre depuis le 11/03/2013
75 Réputation
4 tutoriels rédigés
Équipe
Clemson, Team 12-5, Benson Spring 2013 Membre de l'équipe Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 363
