Introduction
If you're having problems with your memory card, this guide will show you how to remove and replace your memory card in the Nikon Coolpix 995.
Set camera so the memory card compartment is facing you. Place thumb under cover latch where it says "card",  then gently lift straight upwards.
  • Set camera so the memory card compartment is facing you.
  • Place thumb under cover latch where it says "card", then gently lift straight upwards.
Ajouter un commentaire
Now that the Memory card compartment is open, carefully remove the memory card.
  • Now that the Memory card compartment is open, carefully remove the memory card.
Be sure your memory card is facing the right direction, then gently insert it into the memory card slot. After you properly reinsert the memory card, place your thumb on the top of the cover and gently press down until you hear and feel the cover click back into the closed position.
  • Be sure your memory card is facing the right direction, then gently insert it into the memory card slot.
  • After you properly reinsert the memory card, place your thumb on the top of the cover and gently press down until you hear and feel the cover click back into the closed position.
Cory Layman
Membre depuis le 04/10/2011
89 Réputation
3 tutoriels rédigés
Équipe
UW Stout, Team 1-5, Zhou Fall 2011 Membre de l'équipe UW Stout, Team 1-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G5
5 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 1,670
