Introduction
In this guide, we will give you step-by-step instructions on how to detach the LCD screen so that it can be replaced or repaired.
Pièces
Aucune pièce nécessaire.
Remove the memory stick from the camera.
  • Remove the memory stick from the camera.
  • Remove the batteries from the camera.
Ajouter un commentaire
Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver. There is one screw hidden under the AV cover that also needs to be removed.
  • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
  • There is one screw hidden under the AV cover that also needs to be removed.
Pry the back cover from the left side of the camera. Remove the cover gently.
  • Pry the back cover from the left side of the camera. Remove the cover gently.
CAUTION! This is where energy for the flash is stored.  Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
  • CAUTION! This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
  • Newer cameras of descent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
Remove the tape on the right side of the LCD screen.
  • Remove the tape on the right side of the LCD screen.
  • Gently lift the LCD screen from its base.
  • Don't tug on the screen because it is still connected to the logic board.
Be very careful not to touch the flash capacitor on far left when lifting the LCD!! It WILL shock you.
Mark Fraylick - Réponse
Getting the LCD ribbon back "in" is my problem -- hints or suggestions?
richardkujawa - Réponse
I can't get a feel for how the black clip holds the ribbon - insert the new one at an angle?
I practiced a few times with the "bad screen" and managed to figure this out. Unfortunately I can't explain how I did it... if some other person can explain how to make the ribbon connection/clip re-install more predictable I think it'd help anyone else who tries the repair.
Lift the black latch connecting the LCD ribbon to the logic board.
  • Lift the black latch connecting the LCD ribbon to the logic board.
  • Gently pull the LCD ribbon out.
7 autre(s) ont terminé cette réparation.
Nonny
Membre depuis le 11/10/2010
207 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 9-23, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 membres
5 tutoriels rédigés
Good work! Appreciate it.
Oasis World - Réponse
I need a new LCD screen replacement. A link to buy a new one?
William Pullman - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 6,503
