Introduction
This guide will show you how to replace the lens to your camera. Refer to LCD screen disassembly for previous steps.
Pièces
Aucune pièce nécessaire.
'Click' the battery door over to the side.
  • 'Click' the battery door over to the side.
Ajouter un commentaire
Open the battery door. Inside is the memory card and the battery.
  • Open the battery door. Inside is the memory card and the battery.
  • Click over the orange tab and take out the battery.
  • Close the battery lid by pushing it down and sliding it back.
Remove the four screws located on bottom of camera.     (.086in screws)
  • Remove the four screws located on bottom of camera. (.086in screws)
Remove the two screws, then remove the panel. (.113in screws) Remove the two screws, then remove the panel. (.113in screws)
  • Remove the two screws, then remove the panel. (.113in screws)
Remove panel on right side (front view) by removing these two screws. (.196in screws) Remove single screw set underneath panel. (0.083in screw) Remove single screw set underneath panel. (0.083in screw)
  • Remove panel on right side (front view) by removing these two screws. (.196in screws)
  • Remove single screw set underneath panel. (0.083in screw)
Remove the two screws attaching the back panel to the body on the left side. (.188in screws)
  • Remove the two screws attaching the back panel to the body on the left side. (.188in screws)
Gently pull off back cover
  • Gently pull off back cover
Remove the two screws holding on the back panel.  Then remove the three screws on the A/V Out tab (left side). (.188in screws) Remove tab.
  • Remove the two screws holding on the back panel. Then remove the three screws on the A/V Out tab (left side). (.188in screws)
  • Remove tab.
Remove the two screws attaching the front panel to the body on the left side. (.18in screws)
  • Remove the two screws attaching the front panel to the body on the left side. (.18in screws)
Flip up front panel.
  • Flip up front panel.
  • There should be wires still attaching the panel to body. DO NOT TRY TO PULL OFF COMPLETELY
Remove three screws as shown. (Right screw:0.084in, Left screw:0.088in, Middle screw:0.114in)
  • Remove three screws as shown. (Right screw:0.084in, Left screw:0.088in, Middle screw:0.114in)
Carefully pull orange LCD connector up and out of the port.
  • Carefully pull orange LCD connector up and out of the port.
  • Be careful to pull vertically while pushing the black tab upwards
Remove the screw below the LCD (.124in)
  • Remove the screw below the LCD (.124in)
Carefully pull out the plug connecting the LCD to the motherboard.
  • Carefully pull out the plug connecting the LCD to the motherboard.
You can now remove the LCD from the camera body.
  • You can now remove the LCD from the camera body.
  • Insert new LCD and reassemble using the steps in reverse order.
Remove the screw to the right of the flash.
  • Remove the screw to the right of the flash.
  • Remove the screw to the right of the microphone on the bottom. (0.124in)
Remove the two screws on the right side of the camera. (0.115 in screws)
  • Remove the two screws on the right side of the camera. (0.115 in screws)
Remove the four bottom screws. (0.116(fat head)-center screw, 0.112(skinny head)-other screws)
  • Remove the four bottom screws. (0.116(fat head)-center screw, 0.112(skinny head)-other screws)
Remove the 7 screws from the back of the camera. (0.111 in screws)
  • Remove the 7 screws from the back of the camera. (0.111 in screws)
Remove the plug that connects the lens to the left side of the motherboard by firmly grasping the base of the plug and pulling gently sideways away from the camera.
  • Remove the plug that connects the lens to the left side of the motherboard by firmly grasping the base of the plug and pulling gently sideways away from the camera.
Remove the right panel.
  • Remove the right panel.
Remove the screw from the top of the camera. (0.112 in screws)
  • Remove the screw from the top of the camera. (0.112 in screws)
Remove the three screws from the motherboard. (0.112 in screws)
  • Remove the three screws from the motherboard. (0.112 in screws)
  • Detach the orange tab with the foam on top. It will click out of place.
Remove the motherboard by pulling it up, out of the port.
  • Remove the motherboard by pulling it up, out of the port.
Carefully remove the tab that connects the flash to the motherboard from the port by gently pulling connector to the right, out of its port.
  • Carefully remove the tab that connects the flash to the motherboard from the port by gently pulling connector to the right, out of its port.
  • Be careful when removing the connector.
Remove the motherboard from camera body.
  • Remove the motherboard from camera body.
  • Replace with a new motherboard and follow the steps in reverse order to reassemble.
Remove the orange plug by carefully pulling it out. It snaps in and out of place.
  • Remove the orange plug by carefully pulling it out. It snaps in and out of place.
Remove flash unit from it's place in the camera.
  • Remove flash unit from it's place in the camera.
  • The flash unit is still attached to the camera.
Caution! The flash Might still be holding a charge in the Black capacitor avoid contact with other areas of the camera or it WILL discharge.
Seattle98122 - Réponse
Remove the lens from the camera.
  • Remove the lens from the camera.
Luke Baumann
Membre depuis le 13/04/2011
121 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 8-5, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 8-5, Regan Spring 2011
CPSU-REGAN-S11S8G5
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 2,793
