Introduction
You will be removing the back casing of the camera. You will need a Phillips #00 screwdriver and a spudger. You will then be directed to remove screws.
Pièces
Aucune pièce nécessaire.
Place thumb on the battery cover panel on the bottom of the device.
  • Place thumb on the battery cover panel on the bottom of the device.
  • Slide the panel to the right away from the camera.
Ajouter un commentaire
Slide the orange latch outward towards the corner of the camera. The battery should pop out.
  • Slide the orange latch outward towards the corner of the camera.
  • The battery should pop out.
  • Remove the battery and reattach the cover.
After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
Unscrew the two 4.05mm screws on the side next to the buttons.
  • Unscrew the two 4.05mm screws on the side next to the buttons.
Gently wedge the flat end of the spudger between the back case and the wrist-strap mount. The wrist-strap mount is the thin metal piece on the side of the camera.  Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
  • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
  • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
  • Carefully pry the back case away from the camera and then gently lift it off.
Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon. The ribbons are connected to and held in place by small plastic latches. To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up.  The ribbon should slide out easily.
  • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
  • The ribbons are connected to and held in place by small plastic latches.
  • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
  • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
Gently remove the LCD screen.
  • Gently remove the LCD screen.
2 autre(s) ont terminé cette réparation.
Mallory Arend
Membre depuis le 17/01/2011
439 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 5-17, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 membres
7 tutoriels rédigés
Funcionou conforme descrito! Funciona para a Nikon Coolpix S203
geral - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 3,471
