Aller au contenu principal
Nikon Coolpix S70 Display Screen Replacement
Ce dont vous avez besoin
  1. Nikon Coolpix S70 Display Screen Replacement, Display Screen: étape 1, image 1 de 2 Nikon Coolpix S70 Display Screen Replacement, Display Screen: étape 1, image 2 de 2
    • Power off the camera before beginning.
    • Remove the battery by sliding the latch located at the bottom of the camera.
  2. Nikon Coolpix S70 Display Screen Replacement: étape 2, image 1 de 2 Nikon Coolpix S70 Display Screen Replacement: étape 2, image 2 de 2
    • Using a Phillips head #000 screwdriver, remove the five 0.4mm screws on the bottom of the camera.
  3. Nikon Coolpix S70 Display Screen Replacement: étape 3, image 1 de 3 Nikon Coolpix S70 Display Screen Replacement: étape 3, image 2 de 3 Nikon Coolpix S70 Display Screen Replacement: étape 3, image 3 de 3
    • Use a plastic opening tool to carefully separate the back panel of the camera.
    • Once loosened, use your fingers to manually separate the two panels.
  4. Nikon Coolpix S70 Display Screen Replacement: étape 4, image 1 de 3 Nikon Coolpix S70 Display Screen Replacement: étape 4, image 2 de 3 Nikon Coolpix S70 Display Screen Replacement: étape 4, image 3 de 3
    • Using a plastic opening tool, lift both latches that hold the ribbon cables in place.
  5. Nikon Coolpix S70 Display Screen Replacement: étape 5, image 1 de 1
    • Carefully disconnect the orange flat ribbon cables from the latches.
  6. Nikon Coolpix S70 Display Screen Replacement: étape 6, image 1 de 3 Nikon Coolpix S70 Display Screen Replacement: étape 6, image 2 de 3 Nikon Coolpix S70 Display Screen Replacement: étape 6, image 3 de 3
    • Remove the screen from the case of the camera by carefully pushing on the back of the screen.
    • You may need to push with a little force to get the screen to loosen.
4 autres ont terminé cette réparation.
Danielle Morris
Membre depuis le 09/24/15
177 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team 22-2, Rauch Fall 2015 Membre de l'équipe Texas Tech, Team 22-2, Rauch Fall 2015
TTU-RAUCH-F15S22G2
3 membres
1 tutoriel rédigé
Un commentaire
my camera's lens show blury photos and when zooming id makes sound
Aliudin Saleh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 1,096
