Aller au contenu principal
Nikon D90 Rear Display Buttons Replacement
Ce dont vous avez besoin
  1. Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: étape 1, image 1 de 2 Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: étape 1, image 2 de 2
    • Locate the screws on both sides of the camera.
    • Remove the four 6.3 mm Phillips screws using a PH00 screwdriver.
    • Be careful not to strip the screws.
  2. Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: étape 2, image 1 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: étape 2, image 2 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: étape 2, image 3 de 3
    • Use a plastic opening tool to separate the rear case from the camera.
  3. Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: étape 3, image 1 de 2 Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: étape 3, image 2 de 2
    • After, remove the two orange ribbon connectors attached to the interior of the camera with tweezers.
    • Make sure to remove the ribbon cables carefully from the connectors to avoid damaging the camera.
  4. Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: étape 4, image 1 de 2 Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: étape 4, image 2 de 2
    • Remove the screws from the back assembly with a Phillips (PH00) head screwdriver.
    • Remove the ten 5.3 mm Phillips screws.
    • Remove the three 4.3 mm Phillips screws.
  5. Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: étape 5, image 1 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: étape 5, image 2 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: étape 5, image 3 de 3
    • Use a plastic opening tool to separate the LCD and metal plates from the casing.
  6. Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: étape 6, image 1 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: étape 6, image 2 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: étape 6, image 3 de 3
    • Use a plastic opening tool to separate the buttons from the casing.
    • Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver.
jonothon cawley
Membre depuis le 10/20/14
354 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Membre de l'équipe UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 2,561
