Aller au contenu principal
Nikon L310 Camera LCD Broken Replacement
Ce dont vous avez besoin
  1. Nikon L310 Camera LCD Broken Replacement, LCD Broken: étape 1, image 1 de 2 Nikon L310 Camera LCD Broken Replacement, LCD Broken: étape 1, image 2 de 2
    • Here we have the Nikon L310 with the LCD and outer window broken. First of all, I start to remove the screws, but be careful, because they have different lenght.
  2. Nikon L310 Camera LCD Broken Replacement: étape 2, image 1 de 3 Nikon L310 Camera LCD Broken Replacement: étape 2, image 2 de 3 Nikon L310 Camera LCD Broken Replacement: étape 2, image 3 de 3
    • First, we will remove the screws from the bottom side. These only 3. Remember the sizes!
    • Then, the 2 screws of the Right side
    • And finally, the screw above the USB port, on the Left side.
  3. Nikon L310 Camera LCD Broken Replacement: étape 3, image 1 de 2 Nikon L310 Camera LCD Broken Replacement: étape 3, image 2 de 2
    • Now, its time to open the flash, and remove the screw that is allocated inside.
    • Remove the protector, and you will find a silver screw. Remove it.
  4. Nikon L310 Camera LCD Broken Replacement: étape 4, image 1 de 3 Nikon L310 Camera LCD Broken Replacement: étape 4, image 2 de 3 Nikon L310 Camera LCD Broken Replacement: étape 4, image 3 de 3
    • Now, you can separate the rear plastic frame, carefully.
    • As you can see, the entire plastic frame cames out.
    • And here it is, the display!
  5. Nikon L310 Camera LCD Broken Replacement: étape 5, image 1 de 3 Nikon L310 Camera LCD Broken Replacement: étape 5, image 2 de 3 Nikon L310 Camera LCD Broken Replacement: étape 5, image 3 de 3
    • Lift carefully the LCD module, and you will see that is connected by a FPC connector.
    • Release the tab, and unplug the flex cable.
    • Insert the new flex cable and install the LCD on its frame.
    • DONT forget to remove the protective film from the NEW LCD!!
  6. Nikon L310 Camera LCD Broken Replacement: étape 6, image 1 de 1
    • Re-assembly all the parts, and put back the screws. The reparation is DONE! Here you can see the display fixed and the outer window replaced by methacrylate part made by myself ( I have one Dremel... )
9 autres ont terminé cette réparation.
Jaime
Membre depuis le 11/05/13
3 333 Réputation
4 tutoriels rédigés
6 commentaires
Hi! I dropped my camera Nikon B500 and now the screen is black. The display shows and you can view picture plus menu. But you can not see when you want to take a picture. What do you think it is? And could I fix it myself? Thank you so much for helping. You can email me at hazel-04@hotmail.com
hazel-04 - Réponse
What size screwdrivers do I need for this job? And where would I get them?? Thanks.
arlene.rodriguez - Réponse
How much is the screen if I wanna buy it?
Woli Atunbi - Réponse
How much is the screen for L310 coolpix I need 1
So everything went smoothly, except the part when I separated the rear frame, it was way too hard, all screws removed but I feel like I'm gonna break it if I try harder.
Soge T.Sơn - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 41
Total : 5,072
