Introduction
The communication board sends information about the aperture and focus of the lens. If you are having trouble with focus or aperture, then there may be a problem with the communication board.
Pièces
Aucune pièce nécessaire.
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
Ajouter un commentaire
Remove lens mount from the camera.
  • Remove lens mount from the camera.
  • Be careful not to lose any of the three loose pieces that are under the lens mount.
Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
  • Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
  • Make sure you remember the orientation of the metal ring so that it is easier to put back in the device later.
Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
  • Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all). Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all). Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
  • Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
Remove the front case from the camera.
  • Remove the front case from the camera.
  • There is a black plastic ring in the case. Be sure not to remove it, as it can be difficult to put back.
Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
  • Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
Desolder the wires and remove them from the communication board.
  • Desolder the wires and remove them from the communication board.
  • Note: If you are unfamiliar with soldering techniques, click here for a guide.
5 autre(s) ont terminé cette réparation.
Zachary Phillips
Membre depuis le 08/04/2011
178 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 25-26, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 3,994
