Introduction
This guide will teach you how to get to the point where you can replace either the drip stop toggle and/or the brew basket. In a lot of coffee machines after heavy use the brew based can start to leak, and these fixes are very similar, so that is why we did both of these fixes together. Warning: be very careful when unscrewing the brew basket because there is a small spring that releases the drip stop toggle that needs to stay in place. Also you will need a longer skinnier Phillips head screwdriver than the one in the iFixit tool kit to complete this repair.
Pièces
Aucune pièce nécessaire.
Slide brew baskets to open position
  • Slide brew baskets to open position
Ajouter un commentaire
Unscrew three 6mm screws with Phillips head screw driver (need a thinner screwdriver than the one in the ifixit tool kit)
  • Unscrew three 6mm screws with Phillips head screw driver (need a thinner screwdriver than the one in the ifixit tool kit)
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Using needle nose tweezers,   push the bottom of the pin up  from  behind the brew basket Using needle nose tweezers, pull out the pin Using needle nose tweezers, pull out the pin
  • Using needle nose tweezers, push the bottom of the pin up from behind the brew basket
  • Using needle nose tweezers, pull out the pin
Remove brew basket from swinging basket holder
  • Remove brew basket from swinging basket holder
Unscrew one 6mm screw from drip stop toggle Remove drip stop toggle
  • Unscrew one 6mm screw from drip stop toggle
  • Remove drip stop toggle
Naser Aldousari
Membre depuis le 10/10/2017
301 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S13-G69, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S13-G69, Cagle Fall 2017
USFT-CAGLE-F17S13G69
4 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 5
7 derniers jours : 26
30 derniers jours : 99
Total : 424
