Introduction
This is very similar to replacing the tubes in the device, which is show in another repair guide created for the ninja coffee bar. Be very careful with the screws because they are very small. We would suggest the magnetic mat provided by iFixit so you don't lose the screws. Just like the tube repair guide, be careful removing the protective plate because there are a lot of wires that can not be disconnected. Also, make sure to take some pictures of the wiring just incase some of them do slip loose.
Unscrew eight 6mm screws with Phillips head #1 screwdriver
  • Unscrew eight 6mm screws with Phillips head #1 screwdriver
  • Remove bottom cover
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Unscrew three 6mm screws with Phillips head #1 screwdriver
  • Unscrew three 6mm screws with Phillips head #1 screwdriver
  • Remover tube protection plate
Detach valve tubes from valve by squeezing pins and pull tubes away from valve Detach valve tubes from valve by squeezing pins and pull tubes away from valve
  • Detach valve tubes from valve by squeezing pins and pull tubes away from valve
Naser Aldousari
Membre depuis le 10/10/2017
301 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S13-G69, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S13-G69, Cagle Fall 2017
USFT-CAGLE-F17S13G69
4 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 65
