Introduction
This guide shows how to remove the metal plate that covers the motherboard.
Remove the expansion pack cover by pushing in the tab and pulling out.
  • Remove the expansion pack cover by pushing in the tab and pulling out.
Ajouter un commentaire
Lever the expansion pack out using the metal spudger.
  • Lever the expansion pack out using the metal spudger.
  • A small spoon can be used in place of a spudger.
Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
Remove the two front feet of the N64.
  • Remove the two front feet of the N64.
Rotate to top side up and lift off top cover.
  • Rotate to top side up and lift off top cover.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Remove the fourteen screws indicated in the example using the larger Phillips screwdriver. Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
I’m not entirely certain if it's a common difference, but my nintendo 64 doesn’t have fourteen screws, but rather, 8 screws, and instead of 3 heat sinks, it only has the one separate heat sink on the chip close to the memory expansion pack. additionally, aside from the 6 screws closest to the expansion pack, the two other screws are held on by nuts under the metal piece.
Avery Duncan - Réponse
Remove the metal plate indicated in the example by sliding it back and then lifting it up. Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
Remove the small metal bracket from the back of the expansion pack slot.
  • Remove the small metal bracket from the back of the expansion pack slot.
Remove the small metal bracket from the front of the expansion pack slot with the metal spudger. Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
Remove the small metal bracket behind the expansion slot using the spudger. Remove the small metal bracket behind the expansion slot using the spudger.
  • Remove the small metal bracket behind the expansion slot using the spudger.
Remove the seven screws indicated in the example using the larger Phillips screwdriver. Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
Lift off and remove the metal plate as indicated in the example.
  • Lift off and remove the metal plate as indicated in the example.
3 autre(s) ont terminé cette réparation.
LisaF818
Membre depuis le 29/11/2009
95 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 5-4, Regan Fall 2009 Membre de l'équipe Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 33
Total : 8,587
