Aller au contenu principal
Nintendo 64 Motherboard Replacement
Ce dont vous avez besoin
  1. Nintendo 64 Motherboard Replacement, Top Cover: étape 1, image 1 de 1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Motherboard Replacement: étape 2, image 1 de 1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Motherboard Replacement: étape 3, image 1 de 1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Motherboard Replacement: étape 4, image 1 de 1
    • Remove the two front feet of the N64.
  5. Nintendo 64 Motherboard Replacement: étape 5, image 1 de 1
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Motherboard Replacement, Metal Plate: étape 6, image 1 de 2 Nintendo 64 Motherboard Replacement, Metal Plate: étape 6, image 2 de 2
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Nintendo 64 Motherboard Replacement: étape 7, image 1 de 2 Nintendo 64 Motherboard Replacement: étape 7, image 2 de 2
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Motherboard Replacement: étape 8, image 1 de 1
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Motherboard Replacement: étape 9, image 1 de 1
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Motherboard Replacement: étape 10, image 1 de 1
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Motherboard Replacement: étape 11, image 1 de 2 Nintendo 64 Motherboard Replacement: étape 11, image 2 de 2
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Nintendo 64 Motherboard Replacement: étape 12, image 1 de 2 Nintendo 64 Motherboard Replacement: étape 12, image 2 de 2
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Motherboard Replacement: étape 13, image 1 de 2 Nintendo 64 Motherboard Replacement: étape 13, image 2 de 2
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Nintendo 64 Motherboard Replacement: étape 14, image 1 de 1
    • Lift off and remove the metal plate as indicated in the example.
  15. Nintendo 64 Motherboard Replacement, Motherboard: étape 15, image 1 de 1
    • Remove the four screws indicated using the #1 Phillips screwdriver.
  16. Nintendo 64 Motherboard Replacement, Motherboard removal: étape 16, image 1 de 1
    • Lift up and remove the motherboard.
36 autres ont terminé cette réparation.
tonymag28
Membre depuis le 10/28/09
2 154 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 5-4, Regan Fall 2009 Membre de l'équipe Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 membres
15 tutoriels rédigés
3 commentaires
4.2mm doesn't seem right. When I looked to purchase all I saw was 4.5mm and now that I have one in my hand it seems to fit very precisely on the screws on my N64.
negroslim - Réponse
i got the second comment :whyy:
Sqwerks - Réponse
What are the symptoms of a bad motherboard?
Jon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 150
30 derniers jours : 540
Total : 63,650
