Introduction
Removing the back panel is simple, provided you have the correct screwdriver. Nintendo uses a special Tri-wing bit for the case, be sure you have one of these before disassembling!
Remove the cartridge from the console. Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case, turning the screw counter-clockwise. Remove the battery door.
  • Remove the cartridge from the console.
  • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case, turning the screw counter-clockwise.
  • Remove the battery door.
Ajouter un commentaire
Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
  • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Remove the battery from the Nintendo DS.
  • Remove the battery from the Nintendo DS.
Remove the 7 Y0 screws located on the back.
  • Remove the 7 Y0 screws located on the back.
  • It might be helpful to remove the strap from the hole to access the top left screw.
With your hands, pry the back panel off the main case. Separate the back from the front, and set it aside. Separate the back from the front, and set it aside.
  • With your hands, pry the back panel off the main case.
  • Separate the back from the front, and set it aside.
7 autre(s) ont terminé cette réparation.
dnguye26
Membre depuis le 28/10/2009
302 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 18-3, Maness Fall 2009 Membre de l'équipe Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 membres
10 tutoriels rédigés
Where do I get a nintendo DS gamepak?
Kayla Maison - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 54
Total : 11,976
