Introduction
Having trouble connecting to the internet on your Nintendo DS Lite? Replace the Wi-Fi board to get reconnected.
Unscrew the Phillips screw securing the battery cover to the lower case. The screw remains captive to the battery cover.
  • Unscrew the Phillips screw securing the battery cover to the lower case.
  • The screw remains captive to the battery cover.
  • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
A Phillips #000 (PH000) seems to give a more secure fit (no slipping) than the stated Phillips #00.
Ritchie - Réponse
This will be good for mods
Matthew Bevins - Réponse
I'm having a problem getting the screw to unscrew. I have the right Phillips ( it was included with all the stuff I got this) Any tips. it doesn't look like the screw is spinning but i haven't played my Nintendo DS Lite for 3 years.
whittlegirls - Réponse
Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
  • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
  • Remove the battery from the DS Lite.
Ajouter un commentaire
Use the tip of a spudger to pry both rubber feet off the DS Lite. Use the tip of a spudger to pry both rubber feet off the DS Lite.
  • Use the tip of a spudger to pry both rubber feet off the DS Lite.
Remove the following screws securing the lower case to the body of the DS Lite:
  • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-Wing screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-Wing screws
Not mentioned is to remove the jumper/connector below the word "SLOT-2". Case WILL NOT separate otherwise.
Kayla - Réponse
In the separation step below, the third picture show the case with the jumper/connector removed.
Kayla - Réponse
Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite. Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process. Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
  • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
  • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
  • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
Don’t forget to remove the GBA cartridge placeholder before removing the backside
Cees Jan de Boer - Réponse
Lift the lower case away from the rest of the DS Lite.
  • Lift the lower case away from the rest of the DS Lite.
  • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
When you reassemble, make sure that you have the volume and power buttons in place, and make sure they are in the right position to line up with the switches on the motherboard. If they are not aligned, you risk snapping off the tiny switches on the motherboard (in which case, you are in for some soldering work).
Eric - Réponse
I should have read the comments first - broke off the power switch because I didn't know about aligning it. No way I can do soldering, guess it's for the dustbin :-(
Emma -
Whoops, remembered the power button but forgot the volume slider.
I'll do it later.
analbonghits -
Lift both trigger buttons out of the DS Lite. The trigger buttons are held in very loosely by small metal pegs and springs.  Don't lose track of these pieces.
  • Lift both trigger buttons out of the DS Lite.
  • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
  • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
Anything after step 7 is unnecessary if having to replace the left or right trigger button(s).
Nate River - Réponse
The second picture does not show the correct configuration of the button spring. It should be flipped. Look at the trigger on the left of the larger image; that is the correct configuration.
wrekone - Réponse
Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  • Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
There is absolutely no need to follow steps 8-13 if like me, all you needed to do was access the face buttons for cleaning/replacement. Once you have unscrewed the motherboard from the front casing you can just flip it up, making sure you take the front screen with it. You will have full access to the buttons and all of their contacts. No need to remove the wifi board and microphone cable, etc. Also, replacing the ribbon cables for the screen is especially frustrating. Avoid taking them out at all costs, if you can.
James McCarthy - Réponse
what is the "etc."?
Rita Cao -
Use the flat edge of a spudger to pry the Wi-Fi board connector straight up from its socket on the motherboard.
  • Use the flat edge of a spudger to pry the Wi-Fi board connector straight up from its socket on the motherboard.
the i was working on had a different wifi connector. i thought a had broken it but the thing underneath it was just to balance it on the motherboard.
BigD29853 - Réponse
Do you have to put back in the WiFi board? As far as I know it does not require it to play games.
Aiden Harlin - Réponse
Use the flat edge of a spudger to separate the right edge of the Wi-Fi board from the motherboard.
  • Use the flat edge of a spudger to separate the right edge of the Wi-Fi board from the motherboard.
  • The Wi-Fi board is secured to the motherboard with a layer of adhesive.
  • Remove the Wi-Fi board from the DS Lite.
I took it apart successfully and I replaced the screen but I've put it back together and it the green light turns on for about 2seconds quiet dim, brighter for about 1 and then it turns off... I then took the wifi board out, and it turned on! What have I done to it and why doesn't it work with it and only without?!
Brianlewis - Réponse
Exact same symptoms for me : on boot up, green light would stay on for 1 second, then shut down. Without wifi, green light would stay on, but blank screens. In fact, it's because on boot up, DS will check if wifi is present, and stop if there is an error. Then, it checks for upper screen, and after that, for lower screen. If one of these is not responding, DS will turn off. I check my cables (upper screen) and DS started again with no problem.
Alexandre - Réponse
5 autre(s) ont terminé cette réparation.
Matthew Newsom
Membre depuis le 05/01/2010
31 477 Réputation
93 tutoriels rédigés
So I came across a "Prison edition" DSLite out of the Kentucky DOC It I was told that the wifi card was disabled but I take it apart and see that it is still there pluged in and everything you don't happen to know how to turn it back on do you it is a gift for my little brother and would like the WiFi to work.
Vincent - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 44
Total : 9,360
