Introduction
This guide will walk you through replacing your DSi's touchscreen.
Unscrew the two Phillips screws securing the battery cover to the lower case. The screws remain captive to the battery cover.
  • Unscrew the two Phillips screws securing the battery cover to the lower case.
  • The screws remain captive to the battery cover.
  • Grasp the battery cover and lift out of the lower case.
Ajouter un commentaire
Wedge the edge of a spudger in between the top of the battery and its lower case housing and pry upwards to dislodge the battery. Grasp the battery and remove it from the DSi.
  • Wedge the edge of a spudger in between the top of the battery and its lower case housing and pry upwards to dislodge the battery.
  • Grasp the battery and remove it from the DSi.
Two screws are hidden underneath two rubber feet highlighted in red. Use the tip of a spudger to pry the rubber feet out of the lower case.
  • Two screws are hidden underneath two rubber feet highlighted in red.
  • Use the tip of a spudger to pry the rubber feet out of the lower case.
One of the feet did break on me, tweezers came in handy for picking it out
Willie Narvaez - Réponse
Remove the following screws securing the lower case to the body of the DSi:
  • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips screws.
    • One 2.7 mm Phillips screw.
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi. Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing. Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
  • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
  • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Carefully lift the lower casing from its bottom edge. The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
  • Carefully lift the lower casing from its bottom edge.
  • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
  • Pry the volume and SD board cable up from its socket on the motherboard with the flat edge of a screwdriver.
  • once the cable, highlighted in the orange box, is completely removed then you may take off the entire outer casing.
Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
  • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
After reassembling it, I switched my Nintendo DSi xl On and only the blue power light, is on after that it doesn't respond any more, except while charging it blinks
Phillips - Réponse
Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
  • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
do not pry up! pull to one side so you don't disconnect the clip from the motherboard!
Lisa - Réponse
Actually Lisa, you are incorrect. If you pull to one side you WILL end up pulling the connector off the motherboard. It is designed so that you ARE MEANT TO pry it upwards out of the connector. All you need to do is use the point or corner of the flat edge of a spudger (or a small flat-headed screwdriver), push it ever so slightly under the middle of the small white plug where there is a small recess in the connector for just this purpose. Prying the plug up in this fashion you should clear the connector with the spudger by prying it up through the recess rather than catching the connector and pulling it off the board.
James Gravestock -
how to fix if the clip comes off of the motherboard?? please help!
jaime - Réponse
Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets: Lower touchscreen cable
  • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
    • Lower touchscreen cable
    • Lower LCD cable
    • Power board cable
  • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
  • After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
I accidentally broke the retaining flap off of the lower touchscreen’s socket. Is it possible to reattach it?
Thewolfpack23x - Réponse
Mine broke off too. At first I thought it would just pop back in, but when I looked at it under magnification, I can see that a tiny piece of plastic actually snapped off the flap. I think we're farked. Looks like the only way to fix would be to solder on a new cable connector.
trevorsklar -
Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap. Make sure you are flipping up the retaining flap, not the socket itself.
  • Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
  • Make sure you are flipping up the retaining flap, not the socket itself.
  • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
When I was putting mine back together, the flap popped off and when I tried to put it on with a tweezers, it snapped. Any suggestions other than scrap it or use it without the touchscreen? Pictures at https://sites.google.com/site/memesbyluc...
Lucas Hoekstra (Lucas9810) - Réponse
Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap. Make sure you are flipping up the retaining flap, not the socket itself.
  • Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
  • Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
  • With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
Remove the following four Phillips screws securing the motherboard to the DSi framework.
  • Remove the following four Phillips screws securing the motherboard to the DSi framework.
    • Three longer screws.
    • One short screw.
  • Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons . Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap. Make sure you are flipping up the retaining flap, not the socket itself.
  • Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
  • Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
  • Remove the motherboard from the DSi.
Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework. Lift the lower LCD assembly out of the DSi.
  • Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
  • Lift the lower LCD assembly out of the DSi.
Insert the edge of a plastic opening tool between the lower touchscreen and the lower LCD. Carefully run the edge of the opening tool along the perimeter of the touchscreen to detach it from the lower LCD.
  • Insert the edge of a plastic opening tool between the lower touchscreen and the lower LCD.
  • Carefully run the edge of the opening tool along the perimeter of the touchscreen to detach it from the lower LCD.
  • Remove the touchscreen from the lower LCD.
Touchscreen remains.
  • Touchscreen remains.
10 autre(s) ont terminé cette réparation.
As always an excellent well documented and easily explained guide. My DSi touch screen now calibrates and works perfectly. Thank you so much for your excellent site.
Chris Mifsud - Réponse
I followed every step. Once I was done assembling it, I turned it on and the bottom screen flashed. Don't understand why and I'm really frustrated. Please help.
Gabbi M - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 90
Total : 20,008
