Aller au contenu principal
Nintendo DSi Upper LCD/Speakers Replacement
Ce dont vous avez besoin
  1. Nintendo DSi Upper LCD/Speakers Replacement, Battery Cover Removal: étape 1, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement, Battery Cover Removal: étape 1, image 2 de 2
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
  2. Nintendo DSi Upper LCD/Speakers Replacement, Taking out the Battery: étape 2, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement, Taking out the Battery: étape 2, image 2 de 2
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
  3. Nintendo DSi Upper LCD/Speakers Replacement, Lower Case Assembly: étape 3, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement, Lower Case Assembly: étape 3, image 2 de 2
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
  4. Nintendo DSi Upper LCD/Speakers Replacement: étape 4, image 1 de 1
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Nintendo DSi Upper LCD/Speakers Replacement: étape 5, image 1 de 3 Nintendo DSi Upper LCD/Speakers Replacement: étape 5, image 2 de 3 Nintendo DSi Upper LCD/Speakers Replacement: étape 5, image 3 de 3
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Upper LCD/Speakers Replacement: étape 6, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 6, image 2 de 2
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Nintendo DSi Upper LCD/Speakers Replacement, Wi-Fi Board: étape 7, image 1 de 1
    • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
  8. Nintendo DSi Upper LCD/Speakers Replacement: étape 8, image 1 de 1
    • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  9. Nintendo DSi Upper LCD/Speakers Replacement, Motherboard: étape 9, image 1 de 1
    • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
  10. Nintendo DSi Upper LCD/Speakers Replacement: étape 10, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 10, image 2 de 2
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
    • Lower touchscreen cable
    • Lower LCD cable
    • Power board cable
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
  11. Nintendo DSi Upper LCD/Speakers Replacement: étape 11, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 11, image 2 de 2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
  12. Nintendo DSi Upper LCD/Speakers Replacement: étape 12, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 12, image 2 de 2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
    • Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
  13. Nintendo DSi Upper LCD/Speakers Replacement: étape 13, image 1 de 1
    • With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
  14. Nintendo DSi Upper LCD/Speakers Replacement: étape 14, image 1 de 1
    • Remove the following four Phillips screws securing the motherboard to the DSi framework.
    • Three longer screws.
    • One short screw.
    • Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
  15. Nintendo DSi Upper LCD/Speakers Replacement: étape 15, image 1 de 3 Nintendo DSi Upper LCD/Speakers Replacement: étape 15, image 2 de 3 Nintendo DSi Upper LCD/Speakers Replacement: étape 15, image 3 de 3
    • Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
    • Remove the motherboard from the DSi.
  16. Nintendo DSi Upper LCD/Speakers Replacement, Lower LCD Assembly: étape 16, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement, Lower LCD Assembly: étape 16, image 2 de 2
    • Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
    • Lift the lower LCD assembly out of the DSi.
  17. Nintendo DSi Upper LCD/Speakers Replacement, Upper LCD/Speakers: étape 17, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement, Upper LCD/Speakers: étape 17, image 2 de 2
    • Use a pushpin to remove the four plastic screw covers on the front bezel.
  18. Nintendo DSi Upper LCD/Speakers Replacement: étape 18, image 1 de 1
    • Remove the four Phillips screws securing the rear bezel to the front bezel.
  19. Nintendo DSi Upper LCD/Speakers Replacement: étape 19, image 1 de 3 Nintendo DSi Upper LCD/Speakers Replacement: étape 19, image 2 de 3 Nintendo DSi Upper LCD/Speakers Replacement: étape 19, image 3 de 3
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
    • Slightly close the case of the DSi and lift the rear bezel straight up out of the DSi.
  20. Nintendo DSi Upper LCD/Speakers Replacement: étape 20, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 20, image 2 de 2
    • Continue de-routing the microphone and Wi-Fi antenna cables through the opening located on the bottom DSi's framework.
  21. Nintendo DSi Upper LCD/Speakers Replacement: étape 21, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 21, image 2 de 2
    • Remove the five Phillips screws securing the power board to the DSi's framework.
    • Lift and remove the power board from the DSi.
  22. Nintendo DSi Upper LCD/Speakers Replacement: étape 22, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 22, image 2 de 2
    • Push the metal hinge pin inward on the D-pad side of the front lower panel with the tip of a spudger.
    • The pin should move about 3 mm and stop. It is not necessary to try to completely remove the pin.
  23. Nintendo DSi Upper LCD/Speakers Replacement: étape 23, image 1 de 3 Nintendo DSi Upper LCD/Speakers Replacement: étape 23, image 2 de 3 Nintendo DSi Upper LCD/Speakers Replacement: étape 23, image 3 de 3
    • Slightly detach the lower and upper halves of the DSi.
    • Do not completely separate both halves yet. There are several ribbon cables that remain threaded through both panels.
    • De-route the upper LCD and dual camera ribbon cables through the slit near the ABXY side of the front lower panel.
    • Separate the lower and upper halves from each other.
  24. Nintendo DSi Upper LCD/Speakers Replacement: étape 24, image 1 de 1
    • Using your fingers, grasp the microphone cable and de-route it through the hinge.
    • The microphone will likely pop out of its housing, so it is probably easier to completely remove it at this point.
    • De-route the Wi-Fi cable through the hinge.
  25. Nintendo DSi Upper LCD/Speakers Replacement: étape 25, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 25, image 2 de 2
    • Tightly coil the display and dual camera ribbon cables enough to push them through the steel hinge tube.
    • Remove the steel hinge tube.
    • Carefully push both coiled ribbon cables through the tube molded into the front upper panel.
  26. Nintendo DSi Upper LCD/Speakers Replacement: étape 26, image 1 de 1
    • Pry the front-facing camera straight up out of its housing in the front bezel.
  27. Nintendo DSi Upper LCD/Speakers Replacement: étape 27, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 27, image 2 de 2
    • Lift the rear-facing camera out of its housing in the front bezel.
    • Remove the dual camera cable assembly from the DSi.
  28. Nintendo DSi Upper LCD/Speakers Replacement: étape 28, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 28, image 2 de 2
    • De-route the Wi-Fi antenna cable from its channel in the front bezel.
    • Lift the Wi-Fi antenna board straight up and remove it from the DSi.
  29. Nintendo DSi Upper LCD/Speakers Replacement: étape 29, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 29, image 2 de 2
    • Use the flat end of a spudger to pry the right speaker straight up and out of its housing in the front upper panel.
    • Lift the right speaker and set it on top of the upper LCD.
  30. Nintendo DSi Upper LCD/Speakers Replacement: étape 30, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 30, image 2 de 2
    • In the same manner as previously described, remove the left speaker.
    • De-route the left speaker cables from underneath the upper LCD.
    • Lay the left speaker on top of the upper LCD.
  31. Nintendo DSi Upper LCD/Speakers Replacement: étape 31, image 1 de 2 Nintendo DSi Upper LCD/Speakers Replacement: étape 31, image 2 de 2
    • Cautiously wedge the flat end of spudger underneath the upper LCD.
    • Loosen the adhesive by running the spudger along the perimeter of the upper LCD.
    • Lift the upper LCD by its upper right corner and remove it from the front upper panel.
  32. Nintendo DSi Upper LCD/Speakers Replacement: étape 32, image 1 de 1
    • Desolder the speakers from the upper LCD by heating up the solder joints with a soldering iron and simultaneously using a pair of tweezers to pull the speaker wires away from the logic board.
    • If you have never soldered before, we have a guide that makes it easy.
30 autres ont terminé cette réparation.
12 commentaires
The tricky part is getting the upper screen and black ribbon through the hinge. I found that curling them and pushing them through a drinking straw that was cut short first and then pushing the straw through the hinge hole made it a whole lot easier.
Damian - Réponse
So true. I just broke my second ribbon cable while replacing the case. While most repairs on the dsi are relatively easy, this ribbon cable makes any repairs that involve it a nightmare.
Brendan Smith -
I curled the larger (new) cable the same way the smaller one was already curled. Just spend some time doing that until it was shaped that way and it was a lot easier to get both through the molded tube and ring.
Tplan -
I used this guide for change the cover broken by my son.
Thank you
Bompa (Italy)
Bompa - Réponse
While doing this I accident messed something up. When I power on the DSi, the bottom screen just flashes and the DS turns off. What did I do wrong?
Ruben Colon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 22
7 derniers jours : 142
30 derniers jours : 499
Total : 56,441
