Ce dont vous avez besoin
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
8 autres ont terminé cette réparation.
Un commentaire
Be very careful removing the screws - a Google search returns page after page of people who stripped their screws trying to remove the lower case or the power board. My lower case may be permanently attached now. If I did it over again, I would consider dripping a tiny amount of WD40 onto the screws and letting it seep in for a day before I tried removing them...
