Aller au contenu principal
Nintendo DSi XL Rear Bezel Replacement
Ce dont vous avez besoin
  1. Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: étape 1, image 1 de 3 Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: étape 1, image 2 de 3 Nintendo DSi XL Rear Bezel Replacement, Rear Bezel: étape 1, image 3 de 3
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  2. Nintendo DSi XL Rear Bezel Replacement: étape 2, image 1 de 1
    • Remove four Phillips screws securing the front bezel to the rear bezel.
  3. Nintendo DSi XL Rear Bezel Replacement: étape 3, image 1 de 2 Nintendo DSi XL Rear Bezel Replacement: étape 3, image 2 de 2
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  4. Nintendo DSi XL Rear Bezel Replacement: étape 4, image 1 de 2 Nintendo DSi XL Rear Bezel Replacement: étape 4, image 2 de 2
    • Insert a spudger into the gap between the front and rear bezel
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  5. Nintendo DSi XL Rear Bezel Replacement: étape 5, image 1 de 1
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  6. Nintendo DSi XL Rear Bezel Replacement: étape 6, image 1 de 1
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  7. Nintendo DSi XL Rear Bezel Replacement: étape 7, image 1 de 1
    • Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Remove the rear bezel.
3 autres ont terminé cette réparation.
Matthew Newsom
Membre depuis le 01/05/10
39 500 Réputation
67 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 28
Total : 5,069
