Aller au contenu principal
Nintendo DSi XL Start/Select Buttons Replacement
Ce dont vous avez besoin
  1. Nintendo DSi XL Start/Select Buttons Replacement, Battery: étape 1, image 1 de 2 Nintendo DSi XL Start/Select Buttons Replacement, Battery: étape 1, image 2 de 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Start/Select Buttons Replacement: étape 2, image 1 de 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Start/Select Buttons Replacement, Lower Case: étape 3, image 1 de 3 Nintendo DSi XL Start/Select Buttons Replacement, Lower Case: étape 3, image 2 de 3 Nintendo DSi XL Start/Select Buttons Replacement, Lower Case: étape 3, image 3 de 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Start/Select Buttons Replacement: étape 4, image 1 de 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Start/Select Buttons Replacement: étape 5, image 1 de 3 Nintendo DSi XL Start/Select Buttons Replacement: étape 5, image 2 de 3 Nintendo DSi XL Start/Select Buttons Replacement: étape 5, image 3 de 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Start/Select Buttons Replacement: étape 6, image 1 de 2 Nintendo DSi XL Start/Select Buttons Replacement: étape 6, image 2 de 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Start/Select Buttons Replacement: étape 7, image 1 de 2 Nintendo DSi XL Start/Select Buttons Replacement: étape 7, image 2 de 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Start/Select Buttons Replacement, Motherboard: étape 8, image 1 de 1
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
  9. Nintendo DSi XL Start/Select Buttons Replacement: étape 9, image 1 de 2 Nintendo DSi XL Start/Select Buttons Replacement: étape 9, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  10. Nintendo DSi XL Start/Select Buttons Replacement: étape 10, image 1 de 2 Nintendo DSi XL Start/Select Buttons Replacement: étape 10, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  11. Nintendo DSi XL Start/Select Buttons Replacement: étape 11, image 1 de 2 Nintendo DSi XL Start/Select Buttons Replacement: étape 11, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  12. Nintendo DSi XL Start/Select Buttons Replacement: étape 12, image 1 de 2 Nintendo DSi XL Start/Select Buttons Replacement: étape 12, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  13. Nintendo DSi XL Start/Select Buttons Replacement: étape 13, image 1 de 2 Nintendo DSi XL Start/Select Buttons Replacement: étape 13, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  14. Nintendo DSi XL Start/Select Buttons Replacement: étape 14, image 1 de 1
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  15. Nintendo DSi XL Start/Select Buttons Replacement: étape 15, image 1 de 1
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
  16. Nintendo DSi XL Start/Select Buttons Replacement: étape 16, image 1 de 1
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  17. Nintendo DSi XL Start/Select Buttons Replacement: étape 17, image 1 de 2 Nintendo DSi XL Start/Select Buttons Replacement: étape 17, image 2 de 2
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  18. Nintendo DSi XL Start/Select Buttons Replacement: étape 18, image 1 de 2 Nintendo DSi XL Start/Select Buttons Replacement: étape 18, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
  19. Nintendo DSi XL Start/Select Buttons Replacement, Start/Select Buttons: étape 19, image 1 de 1
    • Lift the rubber pad off the back of the start/select buttons.
  20. Nintendo DSi XL Start/Select Buttons Replacement: étape 20, image 1 de 2 Nintendo DSi XL Start/Select Buttons Replacement: étape 20, image 2 de 2
    • Open the display slightly and push the start and select buttons up through the upper case.
    • Remove the start/select buttons from the DSi XL.
2 autres ont terminé cette réparation.
Brett Hartt
Membre depuis le 04/12/10
127 897 Réputation
143 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 4,548
