Aller au contenu principal
Nintendo GameCube Motherboard Replacement
Ce dont vous avez besoin
  1. Nintendo GameCube Motherboard Replacement, Top Case: étape 1, image 1 de 3 Nintendo GameCube Motherboard Replacement, Top Case: étape 1, image 2 de 3 Nintendo GameCube Motherboard Replacement, Top Case: étape 1, image 3 de 3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Motherboard Replacement: étape 2, image 1 de 3 Nintendo GameCube Motherboard Replacement: étape 2, image 2 de 3 Nintendo GameCube Motherboard Replacement: étape 2, image 3 de 3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Nintendo GameCube Motherboard Replacement, Removing the back panel: étape 3, image 1 de 1
    • Gently press down on the clips located on either side of the back panel.
    • Carefully remove the back panel from the GameCube.
  4. Nintendo GameCube Motherboard Replacement: étape 4, image 1 de 1
    • Unclip the controller ports at the front of the unit.
    • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
    • Controller ports are where the controllers plug into the game console, and are a half circular shape.
  5. Nintendo GameCube Motherboard Replacement, Separate the casing: étape 5, image 1 de 2 Nintendo GameCube Motherboard Replacement, Separate the casing: étape 5, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
    • Carefully separate the gray outer casing of the control port and the circuit board.
  6. Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: étape 6, image 1 de 2 Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: étape 6, image 2 de 2
    • The left side of the unit contains the cooling fan and its housing.
    • Carefully remove the two screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
  7. Nintendo GameCube Motherboard Replacement: étape 7, image 1 de 2 Nintendo GameCube Motherboard Replacement: étape 7, image 2 de 2
    • Remove the four Phillips #1 screws retaining the ground springs.
    • Carefully remove the ground springs from the main unit.
  8. Nintendo GameCube Motherboard Replacement: étape 8, image 1 de 2 Nintendo GameCube Motherboard Replacement: étape 8, image 2 de 2
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
  9. Nintendo GameCube Motherboard Replacement, Remove the assembly: étape 9, image 1 de 3 Nintendo GameCube Motherboard Replacement, Remove the assembly: étape 9, image 2 de 3 Nintendo GameCube Motherboard Replacement, Remove the assembly: étape 9, image 3 de 3
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached.
  10. Nintendo GameCube Motherboard Replacement, Motherboard: étape 10, image 1 de 2 Nintendo GameCube Motherboard Replacement, Motherboard: étape 10, image 2 de 2
    • With the Optical Drive Assembly removed, your GameCube should now look like this.
    • Remove the 6 screws (circled in orange) on the heat sink using a #1 Phillips screwdriver.
  11. Nintendo GameCube Motherboard Replacement: étape 11, image 1 de 2 Nintendo GameCube Motherboard Replacement: étape 11, image 2 de 2
    • Gently lift the motherboard from base (as shown in second picture).
  12. Nintendo GameCube Motherboard Replacement: étape 12, image 1 de 2 Nintendo GameCube Motherboard Replacement: étape 12, image 2 de 2
    • Carefully disconnect the ribbon cable connecting the motherboard with the front panel.
    • At this point you can replace the old motherboard with a new one and enjoy your now-functional GameCube!
12 autres ont terminé cette réparation.
mwbisson
Membre depuis le 11/05/09
1 038 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-2, Maness Fall 2009 Membre de l'équipe Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 membres
45 tutoriels rédigés
3 commentaires
What happens if you disconnect that cable (localizated on Step 4)?
Santi12008 - Réponse
Its soldered to the front-board and the connector is on the main-board under the disc assembly, trying to remove it will break it.
Joseph Lalone -
I have been having trouble with my cube shorting out when I insert a memory card into slot A. What is the best way to get at it see if this is the case, and what should I be looking for?
Many thanks
farrell dann - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 40
30 derniers jours : 220
Total : 28,781
