Introduction
Removing the top case will allow you access to the GameCube's internal parts.
Ce dont vous avez besoin
Turn over the Gamecube so that the bottom side is facing up.
Use the 4.5 mm Gamebit screwdriver to remove all four screws.
13 autres ont terminé cette réparation.
Un commentaire
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
