Introduction
If your Joy-Cons detach too easily from your Nintendo Switch, there's a cheap and easy fix: replace the stock plastic buckle locks with third-party metal ones.
Remove the 4 screws on the back of the Joy-Con using a Tri-Point Y00 Screwdriver. Carefully separate the two halves of the Joy-Con.  Be gentle—there are ribbon cables connecting them inside. Remove the single #00 Phillips screw holding the black plastic shell in place.
  • Remove the 4 screws on the back of the Joy-Con using a Tri-Point Y00 Screwdriver.
  • Carefully separate the two halves of the Joy-Con. Be gentle—there are ribbon cables connecting them inside.
  • Remove the single #00 Phillips screw holding the black plastic shell in place.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the Phillips screw and gently pry the metal plate from the Joy-Con (a pair of tweezers might help). Be sure to hold the buckle lock in place so the spring does not fly out. The buckle lock is different for the left and right Joy-Cons. Before you remove the buckle lock, identify the part that you will be replacing it with and make sure it matches the orientation of the original. Pay particular attention to which side is tapered and which side is straight. Remove the buckle lock, being careful to keep the spring inside from flying out.
  • Remove the Phillips screw and gently pry the metal plate from the Joy-Con (a pair of tweezers might help). Be sure to hold the buckle lock in place so the spring does not fly out.
  • The buckle lock is different for the left and right Joy-Cons. Before you remove the buckle lock, identify the part that you will be replacing it with and make sure it matches the orientation of the original. Pay particular attention to which side is tapered and which side is straight.
  • Remove the buckle lock, being careful to keep the spring inside from flying out.
Place the spring into the replacement buckle lock. While compressing the spring, slide the buckle lock into the Joy-Con. Replace the metal cover, making sure not to overtighten the screw. Check that the black plastic latch button is still in place. Reassemble the Joy-Con.
  • Place the spring into the replacement buckle lock. While compressing the spring, slide the buckle lock into the Joy-Con.
  • Replace the metal cover, making sure not to overtighten the screw.
  • Check that the black plastic latch button is still in place. Reassemble the Joy-Con.
3 autre(s) ont terminé cette réparation.
Martin Refseth
Membre depuis le 28/04/2017
285 Réputation
2 tutoriels rédigés
I tried to do this carefully, but I ended up removing the side rail ribbon cables and I had to disassemble the whole thing just to try to get to the inside of these babies. However it seems I messed up, and now I could use some help here. I don't want to lose my left Joy-Con.
Francisco Q. - Réponse
Hi, what exactly do you need help with?
Martin Refseth -
I tryed to do this but the 2nd at the bottom would not come out now my buckle is chiped
TAQI HASSAN - Réponse
Voir les statistiques:
Dernières 24 heures : 15
7 derniers jours : 126
30 derniers jours : 402
Total : 1,674
