Aller au contenu principal
Nite Ize Inova Microlight Casing Replacement
Ce dont vous avez besoin
  1. Nite Ize Inova Microlight Casing Replacement, Case Removal: étape 1, image 1 de 2 Nite Ize Inova Microlight Casing Replacement, Case Removal: étape 1, image 2 de 2
    • Insert the plastic opening tool into the seam of the device.
  2. Nite Ize Inova Microlight Casing Replacement, Battery Removal: étape 2, image 1 de 3 Nite Ize Inova Microlight Casing Replacement, Battery Removal: étape 2, image 2 de 3 Nite Ize Inova Microlight Casing Replacement, Battery Removal: étape 2, image 3 de 3
    • Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
    • Repeat this step for the bottom remaining battery.
    • Do not pull up on the battery as this will bend the metal contact.
  3. Nite Ize Inova Microlight Casing Replacement, LED Light Removal: étape 3, image 1 de 3 Nite Ize Inova Microlight Casing Replacement, LED Light Removal: étape 3, image 2 de 3 Nite Ize Inova Microlight Casing Replacement, LED Light Removal: étape 3, image 3 de 3
    • Place the plastic opening tool below the LED lamp and push away from the device until you hear a click.
    • Continue to remove the LED lamp the with your fingers.
  4. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: étape 4, image 1 de 1
    • Place the plastic opening tool behind the logic board and bend away from the casing
  5. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: étape 5, image 1 de 1
    • The logic board will pop out with ease.
Jennifer Tabadero
Membre depuis le 09/09/14
526 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-1, Bruce Fall 2014 Membre de l'équipe CSU Fullerton, Team 2-1, Bruce Fall 2014
CSUF-BRUCE-F14S2G1
3 membres
3 tutoriels rédigés
Un commentaire
Great Job! found this one night while looking at my little blue light. Great tools, photos. +30
4-16-2017
F3ND1MUS - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 796
