Aller au contenu principal
Nixon Mission Android Wear Battery Replacement
Ce dont vous avez besoin
  1. Nixon Mission Android Wear Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
  2. Nixon Mission Android Wear Battery Replacement: étape 2, image 1 de 1
    • Remove the back plate of watch.
  3. Nixon Mission Android Wear Battery Replacement: étape 3, image 1 de 1
    • Unclip 5 latches from motherboard using a plastic spudger.
  4. Nixon Mission Android Wear Battery Replacement: étape 4, image 1 de 1
    • Remove the 2 3.0mm screws from motherboard using PH00 Phillips head.
  5. Nixon Mission Android Wear Battery Replacement: étape 5, image 1 de 1
    • Carefully remove motherboard & internal screen.
  6. Nixon Mission Android Wear Battery Replacement: étape 6, image 1 de 1
    • Remove from the motherboard the connector with the four cables.
    • Pull the cables upward and the motherboard downward as shown in the picture.
  7. Nixon Mission Android Wear Battery Replacement: étape 7, image 1 de 1
    • Carefully remove the battery from the watch.
6 autres ont terminé cette réparation.
Mauricio Ambrosio
Membre depuis le 11/07/17
191 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S3-G2, Harley Fall 2017 Membre de l'équipe IUPUI, Team S3-G2, Harley Fall 2017
IUPUI-HARLEY-F17S3G2
3 membres
3 tutoriels rédigés
18 commentaires
Hi, would you be able to advise where to purchase a replacement battery?
Simon Seow - Réponse
same here, where to purchase a replacement battery ?
peter.erdogyaraki - Réponse
Thank you for your tuto.
But now, where I can purchase a new battery?
Thank you
COUTURIER - Réponse
Hi! Anyone knows where to buy a new battery?
cristian.carvelli - Réponse
After an extensive search there doesn't seem to be any info out there about battery size…..still
Jerry Jerry J - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 53
Total : 6,264
