Aller au contenu principal
Nokero N400 Suction Cup Replacement
Ce dont vous avez besoin
  1. Nokero N400 Suction Cup Replacement, Remove Battery Cover: étape 1, image 1 de 3 Nokero N400 Suction Cup Replacement, Remove Battery Cover: étape 1, image 2 de 3 Nokero N400 Suction Cup Replacement, Remove Battery Cover: étape 1, image 3 de 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Suction Cup Replacement, Unscrew Back Cover: étape 2, image 1 de 2 Nokero N400 Suction Cup Replacement, Unscrew Back Cover: étape 2, image 2 de 2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Suction Cup Replacement, Pry Open Back Cover: étape 3, image 1 de 2 Nokero N400 Suction Cup Replacement, Pry Open Back Cover: étape 3, image 2 de 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Suction Cup Replacement, Begin Removal: étape 4, image 1 de 2 Nokero N400 Suction Cup Replacement, Begin Removal: étape 4, image 2 de 2
    • Using tweezers, push the edges of the back end of the suction cup inward.
  5. Nokero N400 Suction Cup Replacement, Remove Suction Cup: étape 5, image 1 de 2 Nokero N400 Suction Cup Replacement, Remove Suction Cup: étape 5, image 2 de 2
    • Flip the cover over and remove the suction cup by pulling at an angle.
    • Be careful not to tear the plastic housing.
    • During reassembly, make sure to press down uniformly on the suction cup for an even fit.
Daniel Bumiller
Membre depuis le 01/20/15
201 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 19-2, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 117
