Introduction
Introduction
In this guide, we show how to unscrew and remove the back case of the Nokia 2630b. This enables access to the motherboard, antenna, and LCD screen of the phone.
Pièces
Aucune pièce nécessaire.
Press the release buttons located on either side of the battery cover Pull the battery cover away from the phone
  • Press the release buttons located on either side of the battery cover
  • Pull the battery cover away from the phone
Ajouter un commentaire
Gently pull the battery out of the phone with your fingers Gently pull the battery out of the phone with your fingers
  • Gently pull the battery out of the phone with your fingers
Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
  • Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • The T5 bit has a star shaped end and has "T5" engraved on the side of the bit for easy identification
  • NOTE: Keep the screws in a safe place while you continue working.
Separate the front case from the back case using the iPod opener NOTE: The keypad is a loose piece and may fall out NOTE: The keypad is a loose piece and may fall out
  • Separate the front case from the back case using the iPod opener
  • NOTE: The keypad is a loose piece and may fall out
Remove screws using the same T5 screw bit to release the computer chip from the case
  • Remove screws using the same T5 screw bit to release the computer chip from the case
Carefully lift the black frame off the screen with your fingers
  • Carefully lift the black frame off the screen with your fingers
Carefully remove the computer chip and screen out of the black case with your fingers
  • Carefully remove the computer chip and screen out of the black case with your fingers
The screen is attached to the motherboard by an orange ribbon Carefully detach the ribbon from the motherboard using your fingers
  • The screen is attached to the motherboard by an orange ribbon
  • Carefully detach the ribbon from the motherboard using your fingers
Reattach new screen by connecting the orange ribbon to the computer chip
  • Reattach new screen by connecting the orange ribbon to the computer chip
Place computer chip and screen back into black case Place computer chip and screen back into black case
  • Place computer chip and screen back into black case
Place black frame back over screen
  • Place black frame back over screen
Carefully place keypad back in place Carefully place keypad back in place
  • Carefully place keypad back in place
Snap the front case back in place with the bottom case with your fingers Snap the front case back in place with the bottom case with your fingers
  • Snap the front case back in place with the bottom case with your fingers
Reassemble screws with microscrewdriver
  • Reassemble screws with microscrewdriver
Slide battery back into place
  • Slide battery back into place
Snap battery cover back into place
  • Snap battery cover back into place
Locate the four screws that secure the back case to the rest of the phone. Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
  • Locate the four screws that secure the back case to the rest of the phone.
  • Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
DO NOT PULL APART! There is a wire attaching the speaker to the rear case. It is very important to NOT sever this connection. Because of this, the rear case does not completely detach from the rest of the phone. Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components. Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
  • DO NOT PULL APART! There is a wire attaching the speaker to the rear case. It is very important to NOT sever this connection. Because of this, the rear case does not completely detach from the rest of the phone.
  • Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
Eric
Membre depuis le 07/04/2011
51 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 9-61, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 9-61, Walters Spring 2011
CPSU-WALTERS-S11S9G61
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,783
