Aller au contenu principal
Nokia 6102i Keyboard Replacement
Ce dont vous avez besoin
  1. Nokia 6102i Keyboard Replacement, Battery: étape 1, image 1 de 3 Nokia 6102i Keyboard Replacement, Battery: étape 1, image 2 de 3 Nokia 6102i Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
    • Note: Images on the right side may be hovered over to reveal larger versions.
  2. Nokia 6102i Keyboard Replacement: étape 2, image 1 de 1
    • Lift up the battery from the inside of the phone.
    • Make sure to lift up from the bottom of the battery as shown.
  3. Nokia 6102i Keyboard Replacement, Logic Board: étape 3, image 1 de 2 Nokia 6102i Keyboard Replacement, Logic Board: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    T6 Torx Screwdriver
    $9.99
    J'achète
    • Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
  4. Nokia 6102i Keyboard Replacement: étape 4, image 1 de 2 Nokia 6102i Keyboard Replacement: étape 4, image 2 de 2
    • Use a plastic opening tool to remove the silver cover over the antenna.
    • The covering may not pop right off. It may require some prying in different locations around the top covering.
  5. Nokia 6102i Keyboard Replacement: étape 5, image 1 de 2 Nokia 6102i Keyboard Replacement: étape 5, image 2 de 2
    • Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
  6. Nokia 6102i Keyboard Replacement: étape 6, image 1 de 2 Nokia 6102i Keyboard Replacement: étape 6, image 2 de 2
    • WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
    • With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
    • Disconnect the logic board from the small orange chip.
  7. Nokia 6102i Keyboard Replacement, Keyboard: étape 7, image 1 de 2 Nokia 6102i Keyboard Replacement, Keyboard: étape 7, image 2 de 2
    • Pop out the keyboard from the frame.
    • Once the logic board is removed, the keypad can be easily popped out from the frame with very little force.
    • The picture is showing the three layers: the frame, the keyboard, and the logic board.
Jonathan Brophy
Membre depuis le 04/14/10
1 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 23-78, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 23-78, Johann Spring 2010
CPSU-JOHANN-S10S23G78
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,914
