Aller au contenu principal
Nokia 6590i Battery Charger Connector Replacement
Ce dont vous avez besoin
  1. Nokia 6590i Battery Charger Connector Replacement, Battery: étape 1, image 1 de 2 Nokia 6590i Battery Charger Connector Replacement, Battery: étape 1, image 2 de 2
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Nokia 6590i Battery Charger Connector Replacement: étape 2, image 1 de 1
    • To remove the battery, push it down from the top and pull it out.
  3. Nokia 6590i Battery Charger Connector Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: étape 3, image 1 de 1
    • Grip the front cover from the bottom.
  4. Nokia 6590i Battery Charger Connector Replacement: étape 4, image 1 de 1
    • Lift the front cover off.
  5. Nokia 6590i Battery Charger Connector Replacement: étape 5, image 1 de 1
    • Remove the six screws using a T6 torx screwdriver.
  6. Nokia 6590i Battery Charger Connector Replacement: étape 6, image 1 de 1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Nokia 6590i Battery Charger Connector Replacement: étape 7, image 1 de 1
    • Remove assembly from phone
  8. Nokia 6590i Battery Charger Connector Replacement, Logic Board: étape 8, image 1 de 1
    • The logic board now sits on top of the phone.
  9. Nokia 6590i Battery Charger Connector Replacement: étape 9, image 1 de 1
    • Lift the logic board out of the phone.
  10. Nokia 6590i Battery Charger Connector Replacement, Battery Charger Connector: étape 10, image 1 de 1
    • Locate battery charger connector
  11. Nokia 6590i Battery Charger Connector Replacement: étape 11, image 1 de 1
    • Grasp top and bottom of battery charger connector on the left side
  12. Nokia 6590i Battery Charger Connector Replacement: étape 12, image 1 de 1
    • Lift out the battery charger connector
Colby Leslie
Membre depuis le 10/05/10
1 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 22-3, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 1,865
