Introduction
This guide will show how to remove the phone's logic board.
Pièces
Aucune pièce nécessaire.
Press the button to remove the back cover. Pull the cover downward and lift it off while still pressing the button.
  • Press the button to remove the back cover.
  • Pull the cover downward and lift it off while still pressing the button.
Ajouter un commentaire
Lift the battery out of the phone by pushing down from the top and pulling out
  • Lift the battery out of the phone by pushing down from the top and pulling out
Grip the front cover from the bottom.
  • Grip the front cover from the bottom.
Lift the front cover off.
  • Lift the front cover off.
Locate 6 screws on front of assembly and unscrew them using a T6 torx screwdriver.
  • Locate 6 screws on front of assembly and unscrew them using a T6 torx screwdriver.
Insert spudger along edge of assembly and gently lift assembly away from case
  • Insert spudger along edge of assembly and gently lift assembly away from case
Remove assembly from phone
  • Remove assembly from phone
The logic board now sits on top of the phone.
  • The logic board now sits on top of the phone.
Lift the logic board out of the phone.
  • Lift the logic board out of the phone.
Colby Leslie
Membre depuis le 05/10/2010
1 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 22-3, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,028
