Introduction
How to take out and replace the Logic Board for the Nokia 8265 Cell Phone.
Start by removing the face plate of the phone with a plastic tool.
  • Start by removing the face plate of the phone with a plastic tool.
  • Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
Ajouter un commentaire
Once the face plate is off, you will have exposed the keypad.
  • Once the face plate is off, you will have exposed the keypad.
Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
  • Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
  • Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
  • Make sure to remember what screw goes where.
Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
  • Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
Be careful when removing the Logic Board from the body, lifting it with fingers on both sides.
  • Be careful when removing the Logic Board from the body, lifting it with fingers on both sides.
Now you can put in your new Logic Board, and reassemble the phone.
  • Now you can put in your new Logic Board, and reassemble the phone.
Ligne d'arrivée
Jack
Membre depuis le 20/04/2012
1 Réputation
5 tutoriels rédigés
Équipe
SUNY Cortland, Team 1-1, Getto Spring 2012 Membre de l'équipe SUNY Cortland, Team 1-1, Getto Spring 2012
SUNYCORT-GETTO-S12S1G1
2 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 1,041
