Aller au contenu principal
Nokia E90 Battery Cover and Battery Replacement
  1. Nokia E90 Battery Cover and Battery Replacement, Battery Cover and Battery: étape 1, image 1 de 1
    • In order to remove the back cover, you must press the indicated button.
  2. Nokia E90 Battery Cover and Battery Replacement: étape 2, image 1 de 2 Nokia E90 Battery Cover and Battery Replacement: étape 2, image 2 de 2
    • With the button pressed, apply light pressure and slide the back cover off.
    • This will allow you to access the battery
  3. Nokia E90 Battery Cover and Battery Replacement: étape 3, image 1 de 1
    • In order to remove the battery, pull it out from the same side that the rubber button is on.
To reassemble the back cover, simply slide it back on.
michael mira
Membre depuis le 04/26/11
14 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 18-21, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 20
Total : 5,369
