Aller au contenu principal
Nokia E90 Inside Screen Replacement
Ce dont vous avez besoin
  1. Nokia E90 Inside Screen Replacement, Front Cover: étape 1, image 1 de 1
    • Start with the phone in the flipped open position.
    • You must remove the sticker in the center, below the screen to reveal the center screw.
    • Use a T5 screwdriver to remove all three screws, loosening the front screen.
  2. Nokia E90 Inside Screen Replacement: étape 2, image 1 de 2 Nokia E90 Inside Screen Replacement: étape 2, image 2 de 2
    • Flip the phone to the closed position and turn to the front screen.
    • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
  3. Nokia E90 Inside Screen Replacement, Front Screen and Front Keypad: étape 3, image 1 de 1
    • With the front cover off, the screen and keypad should be loose.
  4. Nokia E90 Inside Screen Replacement: étape 4, image 1 de 2 Nokia E90 Inside Screen Replacement: étape 4, image 2 de 2
    • Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone.
    • With the cable disconnected, the screen should be free for removal or replacement.
  5. Nokia E90 Inside Screen Replacement, Inside Screen: étape 5, image 1 de 1
    • After removing the front screen and front keypad, your device should look like this.
  6. Nokia E90 Inside Screen Replacement: étape 6, image 1 de 3 Nokia E90 Inside Screen Replacement: étape 6, image 2 de 3 Nokia E90 Inside Screen Replacement: étape 6, image 3 de 3
    • Using the T5 Screwdriver, remove the two screws shown.
  7. Nokia E90 Inside Screen Replacement: étape 7, image 1 de 1
    • Make sure to remove the connection shown by gently easing the plastic opening tool underneath the connection and lightly prying the connection apart.
  8. Nokia E90 Inside Screen Replacement: étape 8, image 1 de 2 Nokia E90 Inside Screen Replacement: étape 8, image 2 de 2
    • Gently, lift the board up to reveal the front screen.
  9. Nokia E90 Inside Screen Replacement: étape 9, image 1 de 3 Nokia E90 Inside Screen Replacement: étape 9, image 2 de 3 Nokia E90 Inside Screen Replacement: étape 9, image 3 de 3
    • Using the plastic opening tool, lift and remove the inside screen.
In order to install a new screen, simply follow the steps in reverse order with the new screen.
4 autres ont terminé cette réparation.
Cameron Weinberg
Membre depuis le 04/12/11
540 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 18-21, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 5,293
