Introduction
This guide serves the purpose of replacing the Nokia Lumia 635 headphone jack when the user (you) cannot hear anything when headphones or other media devices are plugged.
Pièces
Aucune pièce nécessaire.
Open the back case of the phone using the plastic opening tool. Remove the battery.
  • Open the back case of the phone using the plastic opening tool.
  • Remove the battery.
Ajouter un commentaire
Remove the six screws shown in the photo using the torx Screwdriver 5mm. Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
  • Remove the six screws shown in the photo using the torx Screwdriver 5mm.
  • Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
Remove the black sticker on the bottom left side (As shown in the picture). Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
  • Remove the black sticker on the bottom left side (As shown in the picture).
  • Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
Using the plastic opening tool separate the plastic cover from the screen.
  • Using the plastic opening tool separate the plastic cover from the screen.
  • On the top left corner you will see the screens flex attached to the mother bothered, watch out when separating them.
Carefully retrieve the audio jack’s flex that is attached to the mother board as shown in the picture.
  • Carefully retrieve the audio jack’s flex that is attached to the mother board as shown in the picture.
  • Attach the new audio jack’s flex to the mother board.
3 autre(s) ont terminé cette réparation.
Benjamin
Membre depuis le 07/10/2014
173 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 7-1, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 7-1, Leahy Fall 2014
USFT-LEAHY-F14S7G1
4 membres
5 tutoriels rédigés
where can you buy the headphone jack?
fERD - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 18
Total : 4,538
