Aller au contenu principal
Nokia N900 USB Replacement
Ce dont vous avez besoin
  1. Nokia N900 USB Replacement, USB: étape 1, image 1 de 1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 USB Replacement: étape 2, image 1 de 2 Nokia N900 USB Replacement: étape 2, image 2 de 2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 USB Replacement: étape 3, image 1 de 1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 USB Replacement: étape 4, image 1 de 2 Nokia N900 USB Replacement: étape 4, image 2 de 2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 USB Replacement: étape 5, image 1 de 1
    • You will now have two halves of the phone.
    • Grab the half of the phone that has the keyboard on it
  6. Nokia N900 USB Replacement: étape 6, image 1 de 1
    • Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
    • Place the key pad and cover to the side for the remaining steps.
  7. Nokia N900 USB Replacement: étape 7, image 1 de 1
    • Use a blue plastic opening tool lift the motherboard out of the back cover
  8. Nokia N900 USB Replacement: étape 8, image 1 de 1
    • Look at the bottom of the motherboard to find the:
    • USB Port
    • Once you've located the USB Port you can search online or call the manufacturer to replace it.
3 autres ont terminé cette réparation.
Troy Posey
Membre depuis le 03/13/14
349 Réputation
2 tutoriels rédigés
Équipe
New Mexico State, Team 1-4, Easley Spring 2014 Membre de l'équipe New Mexico State, Team 1-4, Easley Spring 2014
NMSU-EASLEY-S14S1G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 26
Total : 2,596
