Introduction
Use this guide to bring your Nokia XL Dual Sim back from the dead with a new battery.
Pièces
Aucune pièce nécessaire.
Shut off the device completely. Separate the back cover from the device by gently prying the opening out at the loose locations. Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar item.
  • Shut off the device completely.
  • Separate the back cover from the device by gently prying the opening out at the loose locations.
  • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar item.
Ajouter un commentaire
Once the back cover is removed, the battery will be in plain sight. Again, use the plastic opening tool to lift the battery. From there, you can simply remove it.
  • Once the back cover is removed, the battery will be in plain sight.
  • Again, use the plastic opening tool to lift the battery. From there, you can simply remove it.
You will now take your new battery and insert it into its designated location. Make sure to look at the position the battery was in before you took it out so you don't damage any of it's important parts.
  • You will now take your new battery and insert it into its designated location. Make sure to look at the position the battery was in before you took it out so you don't damage any of it's important parts.
  • Please be aware that your new battery may need to be charged first in order for your device to power back on.
2 autre(s) ont terminé cette réparation.
Shadeed Bilal
Membre depuis le 25/09/2014
216 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 26
Total : 1,950
