Introduction
Steps to replace a broken speaker in the Nook HD+ tablet.
Pièces
Aucune pièce nécessaire.
Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
  • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
    • Pry open the front frame.
Ajouter un commentaire
Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit. Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
  • Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
Carefully remove the bottom frame from center chassis. Detach the battery ribbon from the motherboard.
  • Carefully remove the bottom frame from center chassis.
  • Detach the battery ribbon from the motherboard.
  • Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
In the bottom left hand corner remove the 3 screws that at attached to the speaker
  • In the bottom left hand corner remove the 3 screws that at attached to the speaker
  • Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
  • Replace old speaker with new speaker then follow instructions in reverse order to reassemble
Alex Pelicas
Membre depuis le 17/10/2014
259 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Membre de l'équipe UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 442
